I have a 2000 banshee stock carbs, I just purchased FMF gold series pipes and FMF power core 2 silencers with K&N filter. I'm at 1200' elevation... What's the best jets and jetting to use? Please help need info I'm new at this, thanks
whats the temp youll be riding this in? what type of airbox, lid on or off or any mods to it. FMF also has a recommending jetting page. http://www.fmfracing.com/RiderSupport/JettingCenter
although their recommendations may not be accurate depending on airbox mods
with your setup the FMF recommendations should work perfect. 30 pilot, 260 main 3rd clip position. airscrews 1.5 turns out. if you mod the air filter or run with out the airbox lid you'll need to increase the main jets
edit: this is at 70 degrees 0-1500ft asl as per fmf site. may be a tad lean on main at higher temps by 1 jet size.
fmf sst's have built in arrestors and are approved for forest riding but you must buy set other silencers do not work with them propely and they sound desent it think anyway
