bansheelover Posted November 11, 2003 Report Posted November 11, 2003 i bought my 2001 with a stock motor, I added toomey tr-6 pipes and jetted it to specification ( i think its a 280 main, clip on 4th or 5th groove , im not sure) anyways now if i get into tight corners or turning around, my banshee bogs like crazy, and almost dies. I was wondering if a set of v-force reeds would cure this porblem Somebody please help!!! Matt Quote
Banchetta Posted November 11, 2003 Report Posted November 11, 2003 i bought my 2001 with a stock motor, I added toomey tr-6 pipes and jetted it to specification ( i think its a 280 main, clip on 4th or 5th groove , im not sure)anyways now if i get into tight corners or turning around, my banshee bogs like crazy, and almost dies. I was wondering if a set of v-force reeds would cure this porblem Somebody please help!!! Matt Take the air box lid off or cut the end of the lid. Cut the last 1.5" off the end of the lid right behind the clips so you still have all four clips. That should help out a lot. Also adjust the air screws. You might have to go on the mains when you mod the lid. Quote
bansheelover Posted November 11, 2003 Author Report Posted November 11, 2003 ya when i added the pipes i took the snorkel off and put 12 1" holes in the airbox. I think that it should be getting enough air as it is. I beleive my air screw is 1 1/2 turns out. Should i go more?? Quote
Banchetta Posted November 11, 2003 Report Posted November 11, 2003 ya when i added the pipes i took the snorkel off and put 12 1" holes in the airbox. I think that it should be getting enough air as it is. I beleive my air screw is 1 1/2 turns out. Should i go more?? Vents are worthless, take the lid off or cut it. You have to try different settings on the air screws. Can't tell you where, every shee in every area is different.... Start at .5 turn out from seated and ride it, then try 1 turn out, then 1.5, 2, and 2.5. Let me know what the best setting is. Quote
wheeleymaster99 Posted November 13, 2003 Report Posted November 13, 2003 i dont think it could be the main jet 280 sounds good thats what i run and its fun but have you done anything to the piolet jet you should prob be useing a 28-30 Quote
bansheelover Posted November 13, 2003 Author Report Posted November 13, 2003 no wheelymaster , i havent i honestly dont even know what size pilot i am running like i said, it was stiock before so i guess it would still be the stock pilot, whatever that may be thanks Matt Quote
