jigsaw4089 Posted February 14, 2014 Report Posted February 14, 2014 Hey fellas, i just picked up a stock banshee, i want to upgrade the pipes soon, ive had banshees with T5 and pro circuits, im thinking this time around i want to run SB sheares, how do they perform on a stock stroke/bore unported motor? for now i will just be putting bolt on mods on, then when its time to rebuild I will get it ported!! any input is appreciated, thanks!! Quote
sheerider11 Posted February 14, 2014 Report Posted February 14, 2014 No harm in gettin them now if your gonna utilize them later. Don't expect it to be to snappy tho. Quote
jigsaw4089 Posted February 14, 2014 Author Report Posted February 14, 2014 Oh okay, so pretty much they run better with ported motors? Quote
Finch Posted February 14, 2014 Report Posted February 14, 2014 Same thing said about t5s. But almost any pipe will perform better with porting Quote
jigsaw4089 Posted February 14, 2014 Author Report Posted February 14, 2014 I may just get some T5's for now then get Sheares when i get my motor ported!! Quote
dajogejr Posted February 14, 2014 Report Posted February 14, 2014 Don't forget to rejet once you put the pipes on. On a stock port motor, you'll be happier with T5s. They're a great pipe. It will make a WORLD of difference. Open up the air intake too. Either a better filter, remove the lid, etc. Need to get more air in as well as out....and rejet, rejet, rejet. Quote
WINDYCITYJOHN400 Posted February 14, 2014 Report Posted February 14, 2014 Yeah, unless your going to do some major mods right away. ...the Shearers will be overkill on a stock bike. You're going to lose alot of bottom end and rideability. I'd go with a set of FMF'S, T-5's, Pro Circuits. ..... Quote
jigsaw4089 Posted February 14, 2014 Author Report Posted February 14, 2014 Okay ill keep my eye out on some T5's then, ive had them before on my old bike and loved them....never had experience with FMF's or DMC's. Im just going to ride it piped/jetted for now, So far i have Uni filter, still stock air box and lid, drilled a few holes in the top of the lid but ill remove it once i get pipes, I will be ordering bigger main jets tomorrow. Im around 1100 ft elevation, what Mains would you guys recommend? Quote
dajogejr Posted February 14, 2014 Report Posted February 14, 2014 Make sure you secure the filter to the front of the airbox when you remove the lid, it helps hold it in place. You'll see what I mean if you haven't already. You're in Arizona....so, I doubt you'll be riding in sub zero weather right about now. Depending on rider weight (Load of motor) I think you should start with a 300 main. More than likely, that'll be rich...and you work your way down. I'd buy from 260 to 300 mains (the increment in units of 10.) You'll probably have to turn the air screw 1/2 to 3/4 turn as well.. Try not to make too many adjustments at once. There's a jetting thread at the top of this section. Quote
jigsaw4089 Posted February 14, 2014 Author Report Posted February 14, 2014 Okay right on, ill start with those and fine tune from there, Thanks man i appreciate the info!! Quote
Nightmare Posted February 14, 2014 Report Posted February 14, 2014 Just get them and grow into them. Quote
jigsaw4089 Posted March 5, 2014 Author Report Posted March 5, 2014 Well i ended up buying a set of T3's off ebay for about $200, i hear good reviews about these pipes compared to T5, T6's, cant wait to get them in, also got some K&N pod filters!! Quote
bluebanshee98 Posted March 5, 2014 Report Posted March 5, 2014 Don't forget the outerwears for the pods Quote
jigsaw4089 Posted March 5, 2014 Author Report Posted March 5, 2014 Don't forget the outerwears for the pods For sure on my to get list still lol, should i be fine with my stock timing or do i need to go +4? Quote
bluebanshee98 Posted March 5, 2014 Report Posted March 5, 2014 Go +4 nice cheap mod Sent from my iPhone using Tapatalk Quote
