Solid. will see what I can do.
I am waiting on a crazy order. I got part happy nd just placed order with fast and tm designworks.
I think I found the reason why the bike blew in the first place. Unknown gas, 18mm domes in cool head in sea level elevation
  • 2 weeks later...
Got the top end back together. Didn't pull the crank. No play In bearing. Didn't want to get that deep into the motor yet.
I do have a question tho. I'm rebuilding carb with all new parts and don't k I what the o-ring and 2 small screw things are.
One looks like the pilot, the other looks like the air jet (I think that's what it's called, don't hold me to it) that is in the bell(wide opening) of the carb. The washer goes on top the main. Not sure about the o ring on stock carbs, it's been a while since I've been through them. But it looks like the I ring for the big drain on kehien carbs
two screw things are pilot jets. O ring is for removeable float bowl drain, other piece, if it's brass, is main jet washer
longer small one is pilot(stamped 25). Shorter small one is airjet(usually stamped 1.4 or 1.6)
