foxrider603 Posted February 10, 2014 Report Posted February 10, 2014 Just pick this set up and need to know where i should start at with jetting. It has a 35mm keihin with a 155 main and 50 pilot came from Colorado at 7500 asl. Im at 502ft above sea level with fmf exhaust , k&n filter and boys reeds. Quote
sheerider1026 Posted February 10, 2014 Report Posted February 10, 2014 Needle is super important on this setup. EEK needle middle clip 165 main 48 pilot Quote
Vicstuff Posted February 10, 2014 Report Posted February 10, 2014 Yah what he said or what I said on the phone lol Quote
foxrider603 Posted February 10, 2014 Author Report Posted February 10, 2014 Lol ... vic the set up runs nice thanks again. So the only issue im having is if i let it idle to long without revving it, it bogs . Goes through all the gears an hits power band hard exept for 6th gear, bogs right down in 6th. So what direction should i go. Im running the 165 main an 48 pilot. Sorry for all the questions but im slowly learning this whole jetting thing lol Quote
Sandking Posted February 10, 2014 Report Posted February 10, 2014 Try 42 pilot and do a plug chop to the main Sent from my SCH-I535 using Tapatalk Quote
Strm Trpr Posted February 10, 2014 Report Posted February 10, 2014 How many turns out is the airscrew? If the throttle isn't snapping off idle, bogs, then revs, turn the airscrew in 1/2 a turn. If it gets better, depending how many turns out the airscrew is from fully seated, your pilot might be too small. If you find it best fully seated or 1/2 turn out, go up one size on your pilot. As stated above, do a proper plug chop for the mains. If you don't know how to do one, just ask. Quote
sleeper06 Posted February 11, 2014 Report Posted February 11, 2014 I have always had good results if stock port 42-45 pilot 185 main on ported bikes have gone as high as 210 on mains and 52 pilot Quote
Strm Trpr Posted February 11, 2014 Report Posted February 11, 2014 Still waiting on needle info and turns out on airscrew. Quote
foxrider603 Posted February 11, 2014 Author Report Posted February 11, 2014 Eek needle, on middle notch. 1 and a half turns out on air/ fuel screw Quote
foxrider603 Posted February 17, 2014 Author Report Posted February 17, 2014 So i went down to a 45 pilot and set my air/fuel screw at 1 turn out. Throttle seems alittle snappier but still have thar slight bog in 6th gear Quote
uman1030 Posted February 17, 2014 Report Posted February 17, 2014 when its acting up try pulling the choke out to HALF WAY to see if adding fuel makes it better or worse. may be lean according to sleepers suggestion of 185 main Quote
sleeper06 Posted February 18, 2014 Report Posted February 18, 2014 How hot is she getting and is your electrical up to snuff? Do me a favor u got nothing to loose add fuel leave needle and pilot alone put a 185 in it see if its worse or better . If it gets better all over keep adding one at a time till it wont pull one you find that 1-2 jet spread back down one and plug chop it the rite way. Worse comes to worse your rich . Also very big deal is float height (16mm) . Does it hit a wall or blubber over? Sorry its very hard without feeling it Quote
