I want to purchase a cool head but do not know what dome size to buy.
I have a 2003 banshee with thunder pipes, k&n filter, +4 degree key and boysen reeds, any suggestions would be appreciated.
Thanks
It depends on your elevation. If you are close to sea level, 21cc would probably be as small as you could go running premium pump gas with the timing advanced.
I ride at glamis. Would it be better if I got rid of the degree key?
you could go 20cc's at glamis and keep your timing at plus 4 on pump..you should run race fuel just cause its cleaner fuel,but 21 would be real safe like david said, get a Noss head. way nicer than a cool design
