Texas2stroke Posted February 9, 2014 Author Report Posted February 9, 2014 Its a WSM piston. I think I told you that yesterday? How do the bores look? Possible them might need plated. We were talking about the crank. About the 29L rods being stock length. Cylinders surprisingly look good. No scores in the bore. I think I can actually get by with giving them a good hone. Want more pics Quote
hp2000 Posted February 9, 2014 Report Posted February 9, 2014 Is it a stock stroke cub ? Sent from my iPhone using Tapatalk Quote
joey83 Posted February 9, 2014 Report Posted February 9, 2014 Is it a stock stroke cub ? Sent from my iPhone using Tapatalk Are those cub cylinders?? OP- You say the crank is stock stroke but the cases have been trenched for clearance??? More pics? And your spark plug wasnt "vibrating" loose. That is detonation and that is bad bad. Send that motor out to Redline, passion, fast or somebody to be rebuilt and tuned so it doesnt blow up again if youre not knowledgable on them. Quote
FullThrottle_06' Posted February 9, 2014 Report Posted February 9, 2014 Are those cub cylinders?? OP- You say the crank is stock stroke but the cases have been trenched for clearance??? More pics? And your spark plug wasnt "vibrating" loose. That is detonation and that is bad bad. Send that motor out to Redline, passion, fast or somebody to be rebuilt and tuned so it doesnt blow up again if youre not knowledgable on them. ^This^, Doesn't make two shits what the pistons say, they are junk and going in the trash anyway. You can replace them with whatever you like after you find out what bore those cylinders are at or what size they need to be bored to. Me personally, I would go with wiseco pro-light pistons but there are other, cheaper options out there if you choose to go that route. As far as your cylinders and crank go, send both of those items out to a site sponsored builder and let them check them out for you. Problem solved Quote
Texas2stroke Posted February 9, 2014 Author Report Posted February 9, 2014 Are those cub cylinders?? OP- You say the crank is stock stroke but the cases have been trenched for clearance??? More pics? And your spark plug wasnt "vibrating" loose. That is detonation and that is bad bad. Send that motor out to Redline, passion, fast or somebody to be rebuilt and tuned so it doesnt blow up again if youre not knowledgable on them. I didn't say it was a stock stroke crank. I asked if someone would build an engine with a stroker crank and stock length rods. I have no idea what this engine was built with. I'm not the original owner. Quote
hp2000 Posted February 9, 2014 Report Posted February 9, 2014 From what I can tell its: stock crank stock stroke cub cylinder pistons are 68mm Sent from my iPhone using Tapatalk Quote
Atomic Monkey Posted February 9, 2014 Report Posted February 9, 2014 I have a Vito's 4mil stroker with stock rods, the same 29L you have. I had stock cylinders with a spacer, so I'm not saying this is what you have, just letting you know it is possible to have a stock rod 4mil stroker Quote
Texas2stroke Posted February 9, 2014 Author Report Posted February 9, 2014 Ok. The manual has been useless in identifying parts. Once I know what's it's built with. Then I can shop parts. I'm calling Vito's tomorrow to see about the head and domes. Then gotta call WSM about pistons. I've read that some of the wrist pin heights are different. So don't wanna buy wrong parts. It ran like a raped ape. So I'll put it back with same part specs. Quote
dozer Posted February 9, 2014 Report Posted February 9, 2014 ^This^, Doesn't make two shits what the pistons say, they are junk and going in the trash anyway. You can replace them with whatever you like after you find out what bore those cylinders are at or what size they need to be bored to. may be wrong but i believe wsm and wiseco have different dome profiles so switching piston may require different domes. Quote
sleeper06 Posted February 9, 2014 Report Posted February 9, 2014 Wsm and wiseco forged have same profile Quote
sleeper06 Posted February 9, 2014 Report Posted February 9, 2014 Wsm forged race pistons are my pistons of choice I beleive they are 15g lighter than wiseco Quote
Atomic Monkey Posted February 9, 2014 Report Posted February 9, 2014 I don't know how many options there are for pistons with the wrist pins at different heights for stock rods. I could be wrong, but from what I've found so far is there could be interference issues with the crank and piston skirt. All the stroker pistons I've found revolve around long rod strokers. I know it would help me too if I had solid info about the different pistons, but for me I'm ok with stock height pistons, and then chucking the cyl spacer, doing some porting, and getting domes for the stroker. In the future I believe it will give me the option of going long rod if I roach a main with minimal investment in parts. Quote
hp2000 Posted February 10, 2014 Report Posted February 10, 2014 Post pics of the crank for all you know its a stock one. Sent from my iPhone using Tapatalk Quote
Texas2stroke Posted February 10, 2014 Author Report Posted February 10, 2014 I'll get more pics set up of the jug assy. And of the crank. There is still questions about the jug. People are saying it's a cub. I'm not even sure what that is lol. I'll get some better angles of the crank too. It's still in the engine. I haven't split cases yet. Quote
dozer Posted February 10, 2014 Report Posted February 10, 2014 (edited) Wsm and wiseco forged have same profile "Blaster pistons (Wiseco 573M6800) have a different dome angle than the WSM. So make sure you have a set of domes cut for the WSM piston dome, NOT the wiseco dome." and "as they all said it depends on what piston your motor is using now. If its a blaster piston you are using the banshee piston will be completely wrong. Those two pistons have a different pin to crown height as well as degree dome. With the WSMs also make sure you gap the rings, they might only be 5 to 8 thous, I gap mine .012". getting the info from http://bansheehq.com/forums/index.php?showtopic=125543 Edited February 10, 2014 by dozer Quote
