motoman26 Posted February 1, 2014 Report Posted February 1, 2014 Hi everyone!! this is my first banshee! and I tore down the motor for a complete rebuild.... I bought a new wiseco crankshaft, And for some reason im really lost on how to reassemble the motor with my new crank.... The wiseco crank has o-rings on the pto bearing(which interferes with the halfmoon circlip in the case.) and the two middle bearings and the mag bearing has no o-ring . also the mag. bearing has a little pin, but it doesn't align with the stock slots in the casings... The stock yamaha crank I had, had little pins on all bearings and zero o-rings..... can someone please help me out, because i really dont feel like reopening the motor again after the rebuild... Quote
motoman26 Posted February 1, 2014 Author Report Posted February 1, 2014 I bought it on ebay... It was a wiseco complete top and bottom kit.... Quote
motoman26 Posted February 1, 2014 Author Report Posted February 1, 2014 sorry i have no pics... Quote
camatv Posted February 1, 2014 Report Posted February 1, 2014 th eo- rings sounds to be on the wrong bearing.. you dont really need the o-rings on any of the bearings at all. the bearing with the pin sounds like it was installed backwards.. i thinka you gatta screwed.. Quote
