Stonytony Posted January 29, 2014 Report Posted January 29, 2014 Got a question. I'm wanting to build a 4mil 115long rod and I got a set of trinity stage 4 jugs. Question is if I use the 68mm bore blaster pistons do the jugs have to be changed on the port timing? I may be wrong but blaster pistons have the wrist pin hole 2mm higher so you don't have to use a spacer plate or change port timing? Some one explain this for me Quote
Stonytony Posted January 29, 2014 Author Report Posted January 29, 2014 Also looking for shear sb or rdz sb out frame pipes with just stingers Quote
