Newcs222 Posted January 20, 2014 Report Posted January 20, 2014 I just finished rebuilding the bottom and top end on my shee. Had a problem getting fuel into the jugs and finally by dumping some gas into the jugs it fired up. No I was in the process on seating the rings when i noticed coolant leaking from what looks like the bottom of the jugs exhaust side. Does the bottom jug gasket seal coolant or just air? Can coolant be leaking from here? The head doesn't appear to be leaking. Is there anywhere else to check? It idles perfect. Thanks Quote
Nieskes Posted January 20, 2014 Report Posted January 20, 2014 It could be the rubber plug under the jug. Pull it apart and check it all out. Quote
Newcs222 Posted January 21, 2014 Author Report Posted January 21, 2014 It could be the rubber plug under the jug. Pull it apart and check it all out.where does the plug go? Does it happen to be a flat washer with a weird shape that says up on one side? Quote
Nieskes Posted January 21, 2014 Report Posted January 21, 2014 No it goes in the bottom of the cylinder (assuming you have stock jugs) its a black rubber oval shaped plug. Quote
bansheefromhell Posted January 21, 2014 Report Posted January 21, 2014 Happened to my friends, we left the rubber plugs out of the bottom, it was our first build and forgot about them. We put stop leak in it and it worked but don't do that just pull them and put it in them. Your local yamaha dealer should have some Sent from my iPhone using Tapatalk Quote
sheerider11 Posted January 21, 2014 Report Posted January 21, 2014 Happened to my friends, we left the rubber plugs out of the bottom, it was our first build and forgot about them. We put stop leak in it and it worked but don't do that just pull them and put it in them. Your local yamaha dealer should have some Sent from my iPhone using Tapatalk Wtf?! Quote
Newcs222 Posted January 21, 2014 Author Report Posted January 21, 2014 No it goes in the bottom of the cylinder (assuming you have stock jugs) its a black rubber oval shaped plug.that must be it. Will I have to get new gaskets? Is it on both jugs? Quote
Starwriter Posted January 21, 2014 Report Posted January 21, 2014 Since I'm sure you didn't, I would do a leakdown test BEFORE you tear it apart. Quote
Nieskes Posted January 21, 2014 Report Posted January 21, 2014 that must be it. Will I have to get new gaskets? Is it on both jugs?I would. Quote
bansheefromhell Posted January 21, 2014 Report Posted January 21, 2014 Wtf?!Yeah I told him to but he didn't want to pull the cylinders, it wasn't mine so I could care less Sent from my iPhone using Tapatalk Quote
sleeper06 Posted January 21, 2014 Report Posted January 21, 2014 Is this a cheetah? All cylinders will have some sort of casting plug near where your leak is either pull the plugs clean very good whole cylinder in hot soapy water , blow dry , coat cylinder sleeves in lubricant coat water jacket plugs in threebond 1211 install , let dry for 24 hrs b4 putting fluid back in. Quote
Newcs222 Posted January 21, 2014 Author Report Posted January 21, 2014 Since I'm sure you didn't, I would do a leakdown test BEFORE you tear it apart.do you recommend buying one or just making one? I didn't even think to do a leak down test. Just watched it on YouTube. So I wouldn't be able to tell if I'm running lean from just a idle stand point? Quote
Newcs222 Posted January 21, 2014 Author Report Posted January 21, 2014 Is this a cheetah? All cylinders will have some sort of casting plug near where your leak is either pull the plugs clean very good whole cylinder in hot soapy water , blow dry , coat cylinder sleeves in lubricant coat water jacket plugs in threebond 1211 install , let dry for 24 hrs b4 putting fluid back in.it's not a cheetah. Just a stock set of jugs with a 1mm over bore. Quote
Newcs222 Posted January 21, 2014 Author Report Posted January 21, 2014 Since I'm sure you didn't, I would do a leakdown test BEFORE you tear it apart.can you do this same test while it idling? I was thinking of spraying soapy water while it's running. Would this work? Quote
sprinklerman Posted January 21, 2014 Report Posted January 21, 2014 can you do this same test while it idling? I was thinking of spraying soapy water while it's running. Would this work?No. Sent from my SCH-R970 using Tapatalk Quote
