Randy91 Posted January 8, 2014 Report Posted January 8, 2014 I am going to be running 68.50 pistons on my stock cylinder and was going to pick up a cool head with some big bore domes and have them customed cut. or would custom cutting the stock head work better? and still have enough compression to run 110? thanks Quote
Randy91 Posted January 8, 2014 Author Report Posted January 8, 2014 no, WSM 13 degree piston, has the vitos big bore sleeve in the stock cylinders. heard might run into problems trying to run a cool head with that piston size. Quote
trickedcarbine Posted January 8, 2014 Report Posted January 8, 2014 Good luck keeping that thing sealed up! Get a copper head gasket from TDR and use spray copper on both sides. Then leave the base nuts loose and torque the cylinders to the head first. Then tighten the base nuts like you would a mono jug Quote
