my banshee will start for about 1 or 2 seconds then die, after you start it a couple of times it will back fire, the tors is removed, it has 100 pounds of compression which it enough to run,new coil,cdi,stator, and it is getting gas, some said the pick up coil but the omhs are in spec. i cant think of anything else, any suggestions?
How did you come to this conclusion? The carbs may be etting fuel, but is it etting to the cylinder? Is the wiring correct? Every connection cleaned and tight? Have you cleaned the carbs? Is the choke tube in there?
