PilotYFZ
    kansas city, ks
PilotYFZ's Achievements
  1. My stock clutch basket has play in gear and the basket, so I am looking for a hinson and I was wondering how the gear connects to the basket and if i will be able to do it my self. thanks
  2. I have a 02 Banshee with a play port and all the bolt on mods, and I am going to get some bigger carbs I dont know wether to go with the 34mm PJs or 35mm PWK I want a power gain but still want to have low and mid for trails. I heard the 35's are for 1/2 to full throttle but didnt know how drastic it will be. Any suggestions? Anybody with the 35's, how is your low and mid range power.
  3. my banshee will start for about 1 or 2 seconds then die, after you start it a couple of times it will back fire, the tors is removed, it has 100 pounds of compression which it enough to run,new coil,cdi,stator, and it is getting gas, some said the pick up coil but the omhs are in spec. i cant think of anything else, any suggestions?
  4. im interested how can i get in touch with you
  5. where does everybody send there crank to get it welded? and how much was it. i had a rod bearing go out and i hoping it didn't mess up the crank has anybody experienced this thanks
  6. my buddies banshee will start up then automatically die it has spark when you kick it over, but if you pull it with another 4 wheeeler, it wont spark. it has new cdi,stator,coil, ok compression, it seems to be getting gas.
