Right carb over flow tube leaks fuel when running, floats seem to be set properly, don't know what else it could be....
Edited by tdod101
Well sounds to me like one of three things either the float is "not" set properly , there is trash / debris under the needle seat holding it off its seat and causing the fuel to continue to flow  or the needle itself is worn and needs to be replaced .
Pull the floats outs and use a q tip and toothpaste to Clean the seat then make sure there is no grooving or wear on the float needle. Then set the floats to 21mm
Thanks for the help guys, used the q tip trick, there was a bit of sand stuck in the seat so I gave it a cleaning and it doesn't leak anymore, Sweeeet
