Whats the best choice for gaskets ? Top end / jug base / intake / clutch ? I saw some kits online . K&s and namura . Anyone running these ? Should I just stick to cometic and Athena ?
as long as both surfaces are clean and flat, most gaskets are good.  cometic make great gaskets, ive used them and k/s, i use k/s for their seal kits too.
depending on what size base gasket you run, if its .020" cometic make an AFM gasket, id use one of them, compared to a paper gasket. tho im running .012" so i just run any paper gasket.
much the muchness, just make sure shits clean and flat.
I actually just bought a pack from namura in eBay for $39 and it is an awsome pack it brought every single gasket from top end to the side where gears go, to the radiator hose i couldn't be anymore happier with the pack recommend it 100%
