Juat bought an adjustble timing plate and was wondering if +4 is the best starting point. It is bored .020 i was told but not sure. Or sure if it or the k and filter even matter.
That's because the factory timing is 'fixed' You are going to use the case seam as your pointer on your new plate.
Afford yourself some pipes and reeds too-that's where the biggest power mod for the dollar is when starting out on a modification path :D FMF, Toomey T-5, Pro circuit are all decent choices for a bone stocker....
