Stevv Posted September 24, 2013 Report Posted September 24, 2013 Anybody ever cut the fronts like this. Thinking about doing it but wanted to get some tips before I try. Thanks Sent from my iPhone using Tapatalk - now Free Quote
sprinklerman Posted September 24, 2013 Report Posted September 24, 2013 Use masking tape and a THIN 4 1/2" cutoff wheel. Much easier to cut a straight line than a saw . 1 Quote
possum Posted September 25, 2013 Report Posted September 25, 2013 Use masking tape and a THIN 4 1/2" cutoff wheel. Much easier to cut a straight line than a saw . thats the way. Quote
fappy'97 Posted September 25, 2013 Report Posted September 25, 2013 You better have your grade 10. 1 Quote
sheerider11 Posted September 25, 2013 Report Posted September 25, 2013 i like it. i may do mine like this. Quote
Stevv Posted September 25, 2013 Author Report Posted September 25, 2013 Grade 11 Sent from my iPhone using Tapatalk - now Free Quote
wfobasheeboy Posted September 26, 2013 Report Posted September 26, 2013 Use masking tape and a THIN 4 1/2" cutoff wheel. Much easier to cut a straight line than a saw . ^^XX2XX^^ Same as above but I use a box cutter with a new blade for every cut. And for the rounded cuts I heat the blade with a lighter. Just my 2cents Quote
Stevv Posted September 28, 2013 Author Report Posted September 28, 2013 Finished product!!! Sent from my iPhone using Tapatalk - now Free Quote
sprinklerman Posted September 28, 2013 Report Posted September 28, 2013 Looks great. If you want to finish that edge nice, take a heat gun and slightly melt the edges,,they will loose the rough texture and get glossy and smooth like a factory edge. Quote
Stevv Posted September 28, 2013 Author Report Posted September 28, 2013 Thanks. I'll try that Sent from my iPhone using Tapatalk - now Free Quote
possum Posted September 29, 2013 Report Posted September 29, 2013 cut the fender down so theres no more hole for mount. Quote
Nieskes Posted September 29, 2013 Report Posted September 29, 2013 I use one of these.. Do you use the water hook up or just run er dry? Quote
