frocashmoney24 Posted November 4, 2003 Report Posted November 4, 2003 ok , i guess im gonna trear apart the bottom end this winter, but before i do i wanna see if anyone knows exactly wats wrong. it'll shift into 1-2nd gear fine, but wont shift into 3rd unless goin down a hill(and last time i rode it wouldent shift at all), 4ths fine, and 5th may have a lil problem, and six is ok. a guy that worked on it last time said it may be the gear forks, and i need to spread them apart. Does anyone have anything else to wat it can be cause i wanna get her tapped out without worryin bout the damn thing! Quote
Yamaha_Banshee_Rider Posted November 7, 2003 Report Posted November 7, 2003 it does sound like the shift forks i would just get new ones since you spent so much time taking them apart also check the linkage from the shifter to the case or even the shifter it can bend and not shift right...i know it does the same in diffrent gears but my warrior was the same later Quote
