salmon_slayer06 Posted September 23, 2013 Report Posted September 23, 2013 try a fresh tank of fuel, clean air filter, sync carbs and try again with what you have. Repacking the mufflers helps too I guess. I found 6th to bog some on mine but I'm not touching it. Quote
Jereme6655 Posted September 23, 2013 Report Posted September 23, 2013 Just do the plug chop to ensure your not damaging it. If you do plug chops you aren't going to hurt it later. However if you keep riding it.....even if your running it rich....you could do damage. If its jetted too rich you can actually cause it to over heat..... Quote
3wheeledfanatic Posted September 23, 2013 Author Report Posted September 23, 2013 UPDATE- I went through and recleaned carbs, cleaned air filter, and put in 310 main jets in. The bike runs amazing, it pulls all the gears great especially 6th. The plug chop before showed I was rich but figured I would try the 310s. Thanks for all the help, Quote
