While putting my Shee engine back together I noticed that the RH side crank bearing pin is much shorter than the LH side is this normal? I was thinking that it was to denote LH from RH,but doesn't make sense. Both sides in the case to capture the crank bearings are the same size.
All feedback is welcome and appreciated!!
Thanks in advance
That's the problem,the longer one actually fits as it should by looking at it. the short one is so short that it almost isn't captured in the case. the bear hasn't spun around and clipped itself either...
