Hi all how many differant wire harnesses are there i need one and my cdi is square plugs ,but i noticed some say 87 t0 2002 ,2004 to 2006, and 2003 to 2006 ,is there only 2 types? Round or square? What year do i need? With square plugs? Thanks help is appreciated
i take it that you are shopping on ebay and that is why u are getting so many different years i am pretty sure that the harness never changed during the production 87 to 01 fure sure is the same
It is not the same...early years had round plugs...later harness had square...but some are 5 wire verses 4...also have a change in harness when brake light was introduced. ..unless it was a NH banshee then the brake light was in harness anyway....u can use any harness you want just have to match components around it...or cut and splice everything which isnt worth it IMO
Good to know! Thanks for the heads up. I ALMOST bought an OEM stator from him, but found one in much better shape for a little less. I tried haggling with him in the past on a rear axle/carrier though and he was a straight up douche. Didn't put two and two together that they were the same person till now.  :thanks:
