DeadbeatOperator Posted September 3, 2013 Report Posted September 3, 2013 Well my left cyl won't fire at idle. Pipe gets warm but not as warm as the right side. It used to idle fine and about 15 minutes into a ride it wouldn't idle on its own and the left wouldn't fire until I gave it some good throttle. Pulls fine in the powerband and on the top end is all there. I've cleaned the carbs, made sure there were no air leaks and the reeds looked fine. I also tried new plugs and swapped plug wires. Problem is still there. Any ideas? Quote
DeadbeatOperator Posted September 3, 2013 Author Report Posted September 3, 2013 Don't have a leakdown or compression tester. Yes I know I need one but what would cause something like this that happens suddenly? Quote
1CrazyBastard Posted September 3, 2013 Report Posted September 3, 2013 well I'd get yourself a compression tester check it then we can try to help once we know the compression is good Quote
1CrazyBastard Posted September 3, 2013 Report Posted September 3, 2013 Just to be sure the crossover tube is hooked up between the carbs isnt it ? Quote
DeadbeatOperator Posted September 3, 2013 Author Report Posted September 3, 2013 (edited) Its a billet manifold with a built in crossover and ive already checked to make sure they were all torqued properly. I'm going to see if I can borrow a compression tester from a friend. If I have to buy one, what brand do you suggest? Edited September 3, 2013 by DeadbeatOperator Quote
1CrazyBastard Posted September 3, 2013 Report Posted September 3, 2013 I was talking about the small 2" hose that goes in between the stock carbs which I don't know if you still have stockers if that hose is not connected you will lose a cyl at idle . As far as compression any off the shelf tester from auto zone , advanced auto parts or auto store will work just for sake of testing it .No need buying an expensive one if you don' t use it all the time Quote
DeadbeatOperator Posted September 3, 2013 Author Report Posted September 3, 2013 They are airstrikers so no tube on the carbs, just the crossover on the manifold. Quote
Jereme6655 Posted September 3, 2013 Report Posted September 3, 2013 have you tried turning the idle up on that cylinder? could be just that the idle is too low and is not feeding any fuel at idle Quote
