banshee332 Posted August 27, 2013 Report Posted August 27, 2013 What size do you guys drill the dumps and mains to for a 10 mill cub. I have a set of 39 pwks that are drilled to 118. Is that enough? Quote
LT ROOKIE Posted August 27, 2013 Report Posted August 27, 2013 A friend if mine is running 120 mains, 55-60 pilot on his 10 mill cub. I don't know his dump tube size. Quote
LT ROOKIE Posted August 27, 2013 Report Posted August 27, 2013 A friend if mine is running 120 mains, 55-60 pilot on his 10 mill cub. I don't know his dump tube size. My 39 pwks have a 122 dump tube that were done by a&s Quote
banshee332 Posted August 27, 2013 Author Report Posted August 27, 2013 Thanks, anyone else care to share Quote
mx1986 Posted August 27, 2013 Report Posted August 27, 2013 I believe mine is .115 or .112 main jet but the dumps r .120 on my 38 pwk I think ur alright if ur main jet is smaller then ur dump Cuz ur main is only gona flow as much as ur dump allows. Quote
J-Madd Posted August 27, 2013 Report Posted August 27, 2013 That might be ok on the dumps. YOu may have to drill out the power jets to feed it on the big end though. I think I ran 0.120" with 41 mm PWKs on mine. I run Lectrons on the motor I'm running now. Quote
banshee332 Posted August 27, 2013 Author Report Posted August 27, 2013 What size drill bit is 120? Quote
SlowerThanYou Posted August 27, 2013 Report Posted August 27, 2013 What size drill bit is 120? .120 Quote
SlowerThanYou Posted August 27, 2013 Report Posted August 27, 2013 We run a .120 dump & .120 Main with a DGH needle with bored 39 PWKs on our 643 DMX. Quote
J-Madd Posted August 27, 2013 Report Posted August 27, 2013 I think its a #31 index bit if this chart is correct. http://en.wikipedia.org/wiki/Drill_bit_sizes#Metric_drill_bit_sizes Quote
bada450r Posted August 29, 2013 Report Posted August 29, 2013 Thanks, anyone else care to share i run 118 all the way thru on my 4mil cub...thats at sea level Quote
dozer Posted August 31, 2013 Report Posted August 31, 2013 I know asked about a ten mil but around a 1000ft asl .118 and 55 pilots on my 4mm cub Quote
