mx1986
Everything posted by mx1986
  1. I bought carbs. Would you sell the bowls possibly?
  2. Only sell if you have mikuni bowls
  3. i have a set of chariot pwk billet bowls id like to trade for a set of chariot mikuni billet bows for tm34s. floats attach to bowl.
  4. im looking for billet bowls for tm34 mikuni carbs, let me know what youve got. thanks
  5. Looking for 34mm mikuni carbs. Alky or gas. Text me at 402-380-4714
  6. I'm looking for some 34mm mikuni carbs. Text me at 4023804714
  7. mx1986
    alky jetting
    you think the pump is pushing past fuel?
  8. mx1986
    alky jetting
    Motor has rdz pipes and the ports have been cleaned up. Not sure on the needle will have to check it. The carbs came off a rmk 700 snowmobile that I drilled out the dumps and installed a powerjet setup for pulse pump. The domes are 17cc bought off ebay probably trinity can't remember.
  9. mx1986
    alky jetting
    .120 dumps
  10. mx1986
    alky jetting
    Also at about 900 feet a over sea level
  11. mx1986
    alky jetting
    I've got a 421 cub with 39mm pwks with a .109 main timing a +8 with 17cc shelf domes. I've got a digatron on the bike and still only getting to just under 1000 degrees with the pj's closed. I'm just curious to how small some of your guys main jets are to achieve that 1100 to 1300 egts. My plugs are still not even showing a heat mark. I went down from a .116 to a .109 and only picked up 70 degrees egts.
  12. For sale Sbsf Rdz raw both out 1 side 350$ shipped Sbsf shearer nickle both out 1 side 375$ shipped Spindle mounts banshee taper 10x2 rims 325$ shipped +14 wheelman chassis ladder swingarm no link 250$ shipped +10 aero tube swingarm link setup nice chrome 275$ shipped 13 in rear marvin 150$ shipped 14.5 in marvins leak slowly last all summer 130$ shipped Text for pics phone won't upload 4023802298
  13. mx1986
    dome numbers
    Recently got a 10 mill cub that had some custom domes in it. They read 21 10 .018 on the stator side and 21 10 .022 on clutch side. I know what the numbers stand for I am just curious to why they are different then each other.
  14. Bump still looking
  15. Still looking
  16. Looking for some 12-14 paddle rippers 76 rollout or less. Text me at 4023802298 with what you got.
  17. Got first dibs on this haha
  18. Pm me your phone number and I'll get a hold of you. pretty sure I'll take it
  19. Send me pics of the porting and the bore to 4023804714 if it checks out ok I'll give you 400 plus shipping
  20. Have the cylinders been ran since bored? Pictures of the bore to 4023804714 please
  21. They will tell you all that if you call them.
  22. Very easy to take apart. Release pressure and oil. Push the shaft all the way down then there is a retaining clip that you remove after tapping the collar down. Think there is two seals.
  23. The first frame I built is in the images forum under new drag frame build. I need to post a complete picture yet.
  24. Its more like a stock frame look-a-like. I only built it because I had extra moly setting around for a rigid build that isn't happening.
