twostrokin Posted August 26, 2013 Report Posted August 26, 2013 I want to bore out my jugs,now I don't really know much bout this so I have a cool head do I have to do anything to the head I was also thinking of just getting the stock head shaved down what's your opinions Quote
Surfrjag Posted August 26, 2013 Report Posted August 26, 2013 if you have a coolhead then you shouldn't have to do anything got the stock one besides sell it or throw it in the dumpster. what size domes do you have? Quote
twostrokin Posted August 26, 2013 Author Report Posted August 26, 2013 I'm not sure what size they are but ibwas thinking to bump the compression up Quote
Deadbeat Posted August 26, 2013 Report Posted August 26, 2013 how old is the bike and whats been done to it Quote
twostrokin Posted August 26, 2013 Author Report Posted August 26, 2013 04 hot rods crank coolhead +7 timing advance jetted stock carbs no lid on air box juice box cdi box boyseen reeds pro circuit pipes 12tooth in the front 46 in the rear. The jugs I want to put on are ported and polished no clue who did it or what kinda port job it is. But I just need to know if I bore it do I have to get domes to match the bore size or how does that woek Quote
twostrokin Posted August 26, 2013 Author Report Posted August 26, 2013 I have 150 psi right now on both sides Quote
twostrokin Posted August 26, 2013 Author Report Posted August 26, 2013 Ok so can I run my cool head with the domes I have after boring or do I have to get bigger domes to match the bore size Quote
okbeast Posted August 26, 2013 Report Posted August 26, 2013 Ok so can I run my cool head with the domes I have after boring or do I have to get bigger domes to match the bore size If you're not going to a "big bore" size (68mm +) then you should be good to go. Quote
twostrokin Posted August 26, 2013 Author Report Posted August 26, 2013 Ok thank u like I said before I no nothing bout boring what are the size of bores to cc. I'm looking to have a 373 or something like that...i hope this kinda makes sense lol Quote
twostrokin Posted August 26, 2013 Author Report Posted August 26, 2013 It is just a 04 crank the jugs I want to put on are stock bore but I would like to bore them out what would u recommend and why ditch the juice box Quote
GNR101 Posted August 26, 2013 Report Posted August 26, 2013 why are you boring them out? just to make it bigger cc? Quote
twostrokin Posted August 26, 2013 Author Report Posted August 26, 2013 Yes the power just don't do it for me no more Quote
Jereme6655 Posted August 27, 2013 Report Posted August 27, 2013 you don't bore a 2 stroke for power......you gain almost nothing. You save the bores for when it needs rebuilds......and it will need rebuilds. Again.....don't bore for power....there is none...........4strokes make power by boring, not 2 strokes. Quote
