I want to bore out my jugs,now I don't really know much bout this so I have a cool head do I have to do anything to the head I was also thinking of just getting the stock head shaved down what's your opinions
if you have a coolhead then you shouldn't have to do anything got the stock one besides sell it or throw it in the dumpster. what size domes do you have?
04 hot rods crank coolhead +7 timing advance jetted stock carbs no lid on air box juice box cdi box boyseen reeds pro circuit pipes 12tooth in the front 46 in the rear. The jugs I want to put on are ported and polished no clue who did it or what kinda port job it is. But I just need to know if I bore it do I have to get domes to match the bore size or how does that woek
Ok so can I run my cool head with the domes I have after boring or do I have to get bigger domes to match the bore size
If you're not going to a "big bore" size (68mm +) then you should be good to go.
you don't bore a 2 stroke for power......you gain almost nothing.  You save the bores for when it needs rebuilds......and it will need rebuilds.  Again.....don't bore for power....there is none...........4strokes make power by boring, not 2 strokes.
