Calderon Posted August 17, 2013 Report Posted August 17, 2013 My bike starts on the first kick every time but I just took off my stock reeds and put V2 reeds on. Now it won't start. Do I need to put bigger pilot jets. It's bore out to 66 mm with pro head and 19 domes. FMF pipes and silencers. K@n air filter without lid. Main jets are 320 and stock pilot jets Quote
toytech Posted August 17, 2013 Report Posted August 17, 2013 were the petals new? mine started hard with the old petals in the v2s. do a leak down test to make sure the reed gaskets are sealing. you might go up one size on the pilot jet with your mods. Quote
Calderon Posted August 17, 2013 Author Report Posted August 17, 2013 I bought them use and the petals look good. Im thinking that my pilots need to be changed to 30 Quote
toytech Posted August 17, 2013 Report Posted August 17, 2013 +4 timing plate would wake your shee up!! cheap mod to do. 30 pilot should be fine. also clean the carbs good. Quote
Calderon Posted August 17, 2013 Author Report Posted August 17, 2013 I have the Vito +4 degree key. It was running fine. Then I decided to take off the stock reeds and put the V2 reeds on and it won't start it seems like if it needs more fuel. Quote
toytech Posted August 17, 2013 Report Posted August 17, 2013 make sure the gaskets are sealing the reeds good. I use permatex spray copper coat on mine. or when you were moving the carbs around the pilots got plugged. changing reeds should have not changed it that much. Quote
Calderon Posted August 17, 2013 Author Report Posted August 17, 2013 Ill check tomorrow. Ill take off the carbs and clean them. Ill let you know what happens. Thanks Quote
do-work-son Posted August 17, 2013 Report Posted August 17, 2013 Make sure the choke tube is between the carbs Quote
Colby Posted August 17, 2013 Report Posted August 17, 2013 30 pilot, and make your needle one clip richer (move the clip one notch towards the pointy end of the needle) Quote
Calderon Posted August 17, 2013 Author Report Posted August 17, 2013 Cross tube is on. Colby ill do that after I get off work. Now I need to go buy the pilot jets Quote
Calderon Posted August 17, 2013 Author Report Posted August 17, 2013 Anybody have the 27.5 pilot jets for sale. Here is my #432-631-4852 Quote
Calderon Posted August 17, 2013 Author Report Posted August 17, 2013 Well guy , it was my slide on the carb that got stuck. I just took it off and put it right back and it started fine. Thank y'all guys Quote
