ben123 Posted August 9, 2013 Report Posted August 9, 2013 Just installed the pro circuits yesterday , I installed a 200 main and 27.5 pilot jets. At first I couldn't get it started . Then I basically took off the air filter it was very dirty and oil ly Now when I accelerate the " powerband" is delayed or seems longer for it to kick in. Any idea what's going on and what to adjust? Everything else is stock. Pro circuits 3700 ft elev Quote
Sandking Posted August 9, 2013 Report Posted August 9, 2013 What carb or carbs are you running? Quote
98_shee Posted August 9, 2013 Report Posted August 9, 2013 Your probably running lean. I think a 200 main would be to small. Sent from my iPhone using Tapatalk Quote
hoppedupandcutdown Posted August 9, 2013 Report Posted August 9, 2013 I installed a 200 main Pro circuits 3700 ft elev Your status update says 280 main and 2700 elevation, need better specs. Either way you should bump up about 6-8 sizes on the main when adding pipes. Quote
ben123 Posted August 9, 2013 Author Report Posted August 9, 2013 Oh sorry not 200 but 280 mains I don't know why I put that, I'm running stock carbs Quote
98_shee Posted August 9, 2013 Report Posted August 9, 2013 Go up a size and see if it makes a difference. If your looking for a k&n setup and reeds pm me. Sent from my iPhone using Tapatalk Quote
hoppedupandcutdown Posted August 9, 2013 Report Posted August 9, 2013 Might actually be to rich for your elevation. I run 280's at 1100 ft. Quote
