I was having a problem with me banshee not hitting right on the left side. I found the problem out to be a minor clogged idle jet. It has always started just fine until recently. I went out to start it and it wouldn't hit at all. After i had it pull started it was fine. Whenever its warm it really don't have a problem starting, but after it is cooled off, or if its the first start of the day, it won't hit at all. This problem has never happened except now. I am clueless on the problem. If any one has any suggestions at all, i am ready to hear them. Also, if anyone can help me with more low end power. Thanks.
That was my first thought also. Check your compression. Low compression will cause hard starting when cold and no bottom end power.....
