Any A arm that use hiem joints where they mount to the frame blow as well. They simply do not bolt on. You have to adjust each joint to set the proper Caster. If you don't set the caster up right it will be hard to steer or unstable at high speeds.
I've been thinking about getting some full flights for my girls bike just to get her off her death trap stockers.
Zilla, did you ever change the heims for something better? How old are yours? How are they with getting crap in them? How about water and rust?
^ that would look good on my girls bike. Don't go the cheap way with a-arms an suspension, you will thank yourself in the end if you spend a little more cash on the setup. Do yourself a favor and don't get yfz shocks, stick with aftermarket banshee shocks.
  • Like 1
How does more adjustability blow??
