I am swapping out my 35pwks for some 39's and I was wondering on the manifolds. Would I have to get new manifolds with the rubbers to use the 39's or can I just change the rubber intake boots?
Thanks
Depends on the actual manifold. You probably could get away with new boots, but it might be wise to see if the manifold diameter is smaller then the carb before doing so.
