h20dies Posted May 23, 2013 Report Posted May 23, 2013 Soooo my friend hit the tree on the banshee busted tie rod. Ect ect and we are workin on that but now it won't idle... and won't run good if you let off gas it dies.. It's just not running as fast either. When you totally let off the gas should the gap in the carbs shut all the way? It is slightly open. Quote
Tech AS Posted May 24, 2013 Report Posted May 24, 2013 Well did you do any changes to the carbs at all? stock carbs? If so did you verify the choke tube was in place? And make sure the slides are in the correct carb. I bought a banshee with the slides reversed and at first couldn't figure out why it wouldn't idle. Quote
Eighty9shee Posted May 28, 2013 Report Posted May 28, 2013 question.. I dont think there is a choke tube on my carbs... keihin's... they both have a choke on them.. any inputs? Quote
Uf21 Posted May 30, 2013 Report Posted May 30, 2013 Have you checked the thumb throttle? A mate of mine had the same problem. He had an accident a month or two ago and after messing around for hours, turns out it was the thumb throttle. Played around with it at adjusted it and it was ok. Quote
h20dies Posted May 30, 2013 Author Report Posted May 30, 2013 Might be I adjusted the idle and now it idles. Quote
sleeper06 Posted May 31, 2013 Report Posted May 31, 2013 Not saying its your issue but I have seen cranks come out of phase from accidents on more than one occasion and cause similar symptoms Quote
