m671054 Posted May 20, 2013 Report Posted May 20, 2013 Usually i use honda bond to seal my cases. But i have a billet set with a small gap near the seal holder.it fails a leak test every time. im looking for short term solution until i can make a new adapter. I was hoping to run this weekend. i have seen where some use 1104,1194 threebond both are very similar if not the same as yamabond or honda bond. have also heard of some using 1211. i cant find a product spec sheet for 1211 to compare. Also i looked into ultra grey. it seems okay for a alky motor but not gas. i was hoping a slightly thicker sealer would help. any thoughts or any links to 1211 datasheets in english would help Quote
Pastrykiller Posted May 20, 2013 Report Posted May 20, 2013 1211 will seal up rough mating surfaces. I have also heard that 1104 sealant is thicker and is possibly better to use for said application. Stay clear of yamabond and Hondabond if you dot have a smooth mating surface. Quote
m671054 Posted May 20, 2013 Author Report Posted May 20, 2013 1104 is the same consistency as yamabond. just tested that out. Quote
Pastrykiller Posted May 20, 2013 Report Posted May 20, 2013 I think the term you are looking or is zero tolerance. 1211 should get it done. It forms to any shape. Yamabond is like snot. Quote
