thesoultaker2117 Posted May 13, 2013 Report Posted May 13, 2013 This is one of my latest frames. Couple design changes....lemme know what ya think......good or bad. http://i1268.photobucket.com/albums/jj571/Thesoultaker2117/2013050395153724_zpsb3c2b611.jpg Quote
CAJUN BANSHEE Posted May 14, 2013 Report Posted May 14, 2013 Looks good man. What coolant hoses are those? Quote
possum Posted May 14, 2013 Report Posted May 14, 2013 Yea some seriously long hoses. Was it to sharp of a bend on the top one to run it shorter? Frame looks sweet and you got some trick nerf bar netting. Quote
thesoultaker2117 Posted May 14, 2013 Author Report Posted May 14, 2013 I needed to weld new line fittings in the rad. Its an oversized kx 80 rad. Ran out of time. Wanted to get it rolling. The hoses you can find at home depot or lowes. They are high pressure dishwasher or washer lines. Hold up very well for coolant lines Quote
dajogejr Posted May 16, 2013 Report Posted May 16, 2013 Holy Coolant hose batman...you could probably pick up a tenth just by shortening them...LOL. Kidding.. Do you run those cut knobbies at the track or are they just roll around the garage tires? Curious as to where you run and why those tires if you run 'em. Nice looking setup fo sho. Quote
J-Madd Posted May 17, 2013 Report Posted May 17, 2013 Decent weight. If that's with a bar, too you should get it in the 3.7s with any Cub motor with the right tires, gearing, jockey, etc. Quote
thesoultaker2117 Posted May 17, 2013 Author Report Posted May 17, 2013 Without the bar. But my 145lb ass still keeps it under 400 total. I run 500 ft dirt. And those tires are just roll arounds. I rolled the thing off the trailer, never been out pf 1st gear with it, ran 6.2s at 96. Currently fine tuning it for this weekends event. Hoping to see under 6s and break 100mph. The hoses will definitely go away next year, and the motor mounts up front need fixed. But other than those small things, everytime i dump that clutch, it launches perfectly straight. My goal is eventually setting up my own shop, but for now.......jobs here and there will work Quote
thesoultaker2117 Posted May 17, 2013 Author Report Posted May 17, 2013 Its 86 inches with a 10 over swinger. I hope to have my 7 over done soon. The frame is a stock hybrid. Quote
