Went to the dunes this weekend i started getting high rpm or wot fluttering in the high rpms so i started heading back to camp. So I'm fly in along in 6th gear. all the sudden I feel one side loose all power like the spark plug fell off. I didn't feel or hear anything weird like broken piston. I pulled in the clutch right away to prevent further damage it wanted to keep running on one cyl so I hit the kill switch. Waited for it to cool and checked out everything on the outside of the motor it looked fine so I tried to kick it over. Feels like I'm getting zero compression on the left side wouldn't even burp out that pipe with the throttle open during kick start. Anybody know this symptoms? I'm thinking blown out rings or crank came apart.
It was making compression but it wouldn't burp out the tail pipe with throttle open while kicking over. Maybe a plug wire came loose would that cause high rpm flutter because that was my first problem then this.
Is one cylinder set up for low end and one for top end? I'm sure that would cause some problems  :D
Right now one cylinder is set up for no power (actually inertial loss of power) and one is set up for mid to high ;). Just going to bore the cylinders and get new pistons and cut an inch off the plug wires Problem solver! Not going to buy a new crank this time
