tdod101 Posted May 4, 2013 Report Posted May 4, 2013 Banshee runs fantastic and plugs seem good. Installed a new motion pro throttle cable. Won't start on its on unless I put gas in the cylinders and doesn't seem to want to idle no matter what I do. TORS removed with idle kit Quote
hoppedupandcutdown Posted May 4, 2013 Report Posted May 4, 2013 Look in the air filter side and make sure the new idle screws actually lift the slides when you screw them in. (not running of course) Quote
tdod101 Posted May 4, 2013 Author Report Posted May 4, 2013 Look in the air filter side and make sure the new idle screws actually lift the slides when you screw them in. (not running of course) They do Quote
hoppedupandcutdown Posted May 4, 2013 Report Posted May 4, 2013 little rubber choke hose in the right spot between carbs? Quote
JUSTWANNARACE Posted May 4, 2013 Report Posted May 4, 2013 Are the slides in correct with the cutaway tword the filter? Quote
tdod101 Posted May 5, 2013 Author Report Posted May 5, 2013 Yes and yes everything seems to be perfect. There's fuel coming out of the left carb over flow but not the right Quote
hoppedupandcutdown Posted May 5, 2013 Report Posted May 5, 2013 if fuel is coming out the overflow, either your needle and seat isn't sealing or your float is not set properly,or not put together right. Quote
tdod101 Posted May 5, 2013 Author Report Posted May 5, 2013 if fuel is coming out the overflow, either your needle and seat isn't sealing or your float is not set properly,or not put together right. All new parts were used, got the moose carb rebuild kit from fast racing, maybe ill put the stock needle and seat in Quote
sleeper06 Posted May 5, 2013 Report Posted May 5, 2013 Carb bowls are on the wrong side switch em problem fixed Quote
tdod101 Posted May 5, 2013 Author Report Posted May 5, 2013 Carb bowls are on the wrong side switch em problem fixed I checked that, the one with the BB in it should be on the left ?? Quote
hoppedupandcutdown Posted May 5, 2013 Report Posted May 5, 2013 How's it going? I read someone else on here thought they might have torn the o-ring putting in the seat, never heard back on if that was it though. I've never had a problem with those Moose kits, not saying they are all good. Quote
tdod101 Posted May 5, 2013 Author Report Posted May 5, 2013 BB on choke knob side There was no tube so I added one, same problem. No start on its own and left carb overflows... Quote
hoppedupandcutdown Posted May 5, 2013 Report Posted May 5, 2013 I'd say clean the carbs - especially check the pilot jets and choke circuit, and maybe got something in the needle and seat. Quote
