quadpro26 Posted May 2, 2013 Report Posted May 2, 2013 DRAG PARTS:10mm supercub topend (cyl, piston, head w/domes) $800 4mm longrod crank $300 4mm cub topend $900 (cyl, pistons, head w/domes) 4mm vitos engine (crank, cyl, head w/domes, pistons, cases w/no wack)$1000 7mm crank $500 poilished cases (no wack) $250 40mm kehin alky carbs $400Kehin 34PJ carbs $200 Hinson basket w/stock ratio straight cuts $375 (stock ratio) straight cuts w/out basket $240DMX cylinder (18mm x 85mm bore) ported but not coated $40018mm crankworks billet crank (big pin/big wheel 133mm rod) $500custom painted plastics: candy red w/ghost chains and skulls (front, tank, radiator plastics w/cascade grill) $225alum insert $15billet handlebar clamp $20chrome v bars $20STOCK PARTS: complete stock ignition $250 (stator, flywheel, harness, coil, cdi, reg)stock tranny $110sprocket hub $30brake hub $15set lower a-arms $65spindles (old syle) $30setset tie-rods (w/ends) $30radiator $20complete front brake assy (new style) $50rear brake lever $25rear shock $60rear linkage $20chrome sm link $40foot pegs $20front hubs w/rotors $30tank $20rear 10x9 alum wheels $100stock rear spring $15stem mount $5swingarm sleeve $10rear brake system polished w/billet rez $125cases (w/chain break) $125cases (w/out chain break) $200clutch cover $20 Quote
CrashRyan Posted May 2, 2013 Report Posted May 2, 2013 Would you be interested in selling just the stator & flywheel? 1 Quote
quadpro26 Posted May 2, 2013 Author Report Posted May 2, 2013 I'd rather sell the whole ign., pm's returned I have 2 sets of works, the ones pictured need seals and recharged $100 Other set I have are good. $200 Quote
abriana'sbanshee Posted May 2, 2013 Report Posted May 2, 2013 Did u have pics for the billet handlebar clamp? Quote
Starwriter Posted May 2, 2013 Report Posted May 2, 2013 I have 2 sets of works, the ones pictured need seals and recharged $100 Other set I have are good. $200 If the $100 Works ressi shocks pictured are about 14 1/2" center to center, I'll take them. PM sent. Quote
quadpro26 Posted May 2, 2013 Author Report Posted May 2, 2013 Works need seals and recharged (oil leaked but worked great til then Quote
abriana'sbanshee Posted May 3, 2013 Report Posted May 3, 2013 Pm for the handlebar clamp with pictures please!! Quote
James_21 Posted May 5, 2013 Report Posted May 5, 2013 Do you have an extra cdi box with the five wires by any chance? Quote
Racerx812 Posted May 5, 2013 Report Posted May 5, 2013 Are the cylinders/cranks/pistons new or used? Thank you Quote
