I have a 4mm cub making 99.5 hp rear wheel and a +12 Swingarm on it and it spins like crazy at launch then its perfect once I grab 3rd gear wheelies just a little with 12 paddle extremes I'm think about switching to a +10 Swingarm or buying 12 paddle staggereds or 14 paddles what do u think will work best?
More info. Weight of bike and rider. type of sand. tire pressure and ro. gearing front back and primary. clutch spring and lockup type. just a few more details to give you an accurate suggestion
Whats a regular lockup? Answer all these question and youll be suprised at how good the info you get will be. i already see 2 problems in your setup. i bet there is 1 more
Gear up to 16-41. Only run up to 5th gear. the extra wheel speed should help launch. i also rec all stock springs. possibly cut 1 coil on 3 of them. This will let the clutch slip a little not blowing the tires off so bad and help if it wanted to bog. then maybe add 1 nut to each arm if the clutch slips on topend.adjust tire pressure between 3-5lbs depending on sand conditions. to recap problem 1 is to low gear causing excessive spin. problem 2 is to much spring in clutch. problem 3 was the bonus. 6th gear is not for sand drags in my opinion. This should help. dont overtire. it will slow you down on the longer runs
  • 4 weeks later...
Tried my new setup this weekend and worked pretty well I think in oregon sand it will be dead on here in Washington sand is more course. I put half stock springs back in and am running a 15 41 gear setup it didn't wanna launch 2nd with the 16 front also running 3.5 tire pressure
