BuckeyeShee21 Posted April 20, 2013 Report Posted April 20, 2013 Have 10 mil cub. Was on gas, stock milled head .04 squish, 156 compression in both cylinders. Converting to Alky so I ordered a noss head from Jeff at fast and had him cut me domes. I wanted to be around 170 psi or so. He said I needed 25cc domes. ( also running +10 timing) put it all together...... 125 psi in each cylinder. Don't know what I should do. Its strictly 300 ft quad. Oh and the squish now is almost .07 Quote
BANSHEE HP Posted April 20, 2013 Report Posted April 20, 2013 You'll have a tough time detonating that's forsure. Not sure what your elevation is but here in Michigan a 19-21cc dome will get you near or at 170. And for what its worth .040 is mighty tight, low .50's would be more on track Quote
10milmike Posted April 20, 2013 Report Posted April 20, 2013 I have 24 cc custom cut domes from titan and I have 180 psi Quote
BuckeyeShee21 Posted April 20, 2013 Author Report Posted April 20, 2013 You'll have a tough time detonating that's forsure. Not sure what your elevation is but here in Michigan a 19-21cc dome will get you near or at 170. And for what its worth .040 is mighty tight, low .50's would be more on track . Yea I know .04 is a bit tight. but now I'm at .07. Elevation here is about 1100ft. I'll have to call him but he was dead set on giving me 25's because of my timing. Quote
BuckeyeShee21 Posted April 20, 2013 Author Report Posted April 20, 2013 I understand without knowing port timings And such its hard to estimate where you are going to be at.... just don't understand why its so drastically low Quote
BuckeyeShee21 Posted April 20, 2013 Author Report Posted April 20, 2013 Honestly I'm not sure. I got the motor off a member on here. Motor was built by d&m racing in Arizona. They won't answer emails or return any of my calls. I ran the motor all last season... ran strong on gas. I understand I'm asking for answers and don't have all the info needed. Quote
BANSHEE HP Posted April 20, 2013 Report Posted April 20, 2013 I have 24 cc custom cut domes from titan and I have 180 psi Big difference between a cub at 68mm to a 73mm Cheetah Quote
crazycracker520 Posted April 20, 2013 Report Posted April 20, 2013 I'm pretty shure D&M went tits up! At least that's what I heard! A little while back I noticed an awful lot of there bikes on CL. Also heard they built a bunch of grenades and that's what did them in! crazycracker Quote
BANSHEE HP Posted April 20, 2013 Report Posted April 20, 2013 I'm pretty shure D&M went tits up! At least that's what I heard! A little while back I noticed an awful lot of there bikes on CL. Also heard they built a bunch of grenades and that's what did them in! crazycracker theyre still on facebook posting everyday of rzr's and porting banshee cylinders. Quote
Jereme6655 Posted April 20, 2013 Report Posted April 20, 2013 im thinking jeff may have realized that +10 timing on gas is a hell of a lot of timing. Either way i'd say just give him a call and see what he says. Quote
BuckeyeShee21 Posted April 20, 2013 Author Report Posted April 20, 2013 Yea I heard some bad things about d&m but this motor gave me about 50 strong passes or so last year. I know Jeff will set me straight. He's a damn good guy and his motors run strong. What's the lowest compression you guys heard of anyone running a cub on alky? This being my first time with alky that's why I want to experiment with a motor that's already been used a bit.... that way if something happens its not that big of a loss. Quote
10milmike Posted April 21, 2013 Report Posted April 21, 2013 Doug is still in business. They build some fast bikes. Hit Doug up on facebook, They are hard to get of ahold of but my old 370 was built by them and it ran great. Quote
Nightmare Posted April 21, 2013 Report Posted April 21, 2013 Doug is still in business. They build some fast bikes. Hit Doug up on facebook, They are hard to get of ahold of but my old 370 was built by them and it ran great. X2, Doug knows his shit. Sent from my SGH-T679 using Tapatalk 2 Quote
