Clutch help needed
fkonieczny
Ok here it is! I tried to adjust my clutch. I have the side cover off and am adjusting the screw in the center of the clutch. I have the clutch feeling perfect and the arm on top of the engine case (left side) is lined up with the arrow. Problem is when its in gear and clutch lever pulled in, the gears still turn when I roll the quad. It acts like the clucth isnt even pulled in. When I do pull in the clutch lever, the outside plate moves out. If I turn that screw to tight, t hen the clutch lever is WAY to tight. What gives. It worked fine before I started messing with it. I am not sure what I got out of whack. THe clutch is stock by the way....... a 99 with low hours.
