I have a ten mil cub with a mild drag port on alky with a drag frame 12in front 15 out back. i have stock primary ratio. 25in x 12 x 11 extremes.
My question is what would be a good sprocket starting point right now it's a 14 40
im to fat to launch 2nd gear.  i break the gears all the time..
1-5 is way better in my opinion.  after you figure out how to make them work it for you.
R1 clutch 10 plate billet basket. I don't have a lockout clutch yet.
IMO, that's way too much clutch. When you start getting over 700cc or smaller nitrous/boosted engines you can start using that many clutch plates efficiently. 10 plates will work, but pretty hard to get slip out of them. Then you carry the penalty of accelerating that extra weight.
