Leakdown test on Cheetah PV
The 230's are a good starting point. If it has a high rpm bog then comes alive again, go up on them. This is a sign the PV's are opening too late. Remember, as you make changes to the pv you will also have to look at jetting again. If it feels like it's lacking on bottom to mid, the PV's could be opening too soon. Best time to consider some dyno time, these aren't as simple to tune as a cub or stock cyl motor.
-Brandon
