If you're talking about rear wheel hubs, they're threaded into the hub with loctite. Grind down the stripped threads so it doesn't damage the hub when you back it out. Heat the hub slightly and back it out. They're just 3/8" stainless button head allen bolts. I have some if you can't find them local to you. If you're talking about front wheel hubs, I would imagine they're the same, but don't know for sure.
