mccarthy_21 Posted March 27, 2013 Report Posted March 27, 2013 desperate for advice. I purchased a 97 banshee saturday, and that day i never noticed it, i even felt the exhaust pipes, but it is not firing on left cylinder. The engine and exhaust are stock. Has stage 1V trinity 2-1 carb setup, new stator and cdi which is red i believe a ricks hot shot. All previously installed by owner. oh ya right sides warms up and sounds great, and left occasionally pops.what I've done:-cycled two new plugs thru Left side-checked spark, and both side have great spark, and i believe both sides fire everytime?-single carb setup getting fuel-check reeds look good-swapped plug wires for hell of it-searched harness for bad spots-grounds seem good-i could not find my compression kit, and this is cheesy but i could not hold my finger over hole, both sides popped off with resonable force.-could not get flywheel off to check key, my tool broke i even used a little heat and slight hammer taps.Granted i need to truly check compression what am i missing. please visit link for more info:http://www.trx250r.net/forum/engine-transmission/21183-banshee-2-1-carb-engine-misses-left-cylinder.html Quote
250rbanshee Posted April 7, 2013 Report Posted April 7, 2013 Oem stator and cdi and your problem should be solved. Quote
mccarthy_21 Posted April 12, 2013 Author Report Posted April 12, 2013 I did leak down test putting 6lbs in for 6 minutes and 4 after the 6 mintes were up. The compression was 30psi left and 60psi right. Upon tear down left piston was scored and both cylinders were beyond out of spec, so i punched it out to 65mm. Still same pronlem as before good psi though. I have oem cdi on the way. Will be inspecting stator area more after i make a puller. Does the 2 into 1 carb play any affect here. also posted on http://www.trx250r.net/forum/engine-transmission/21183-banshee-2-1-carb-engine-misses-left-cylinder.html thanks Quote
Vicstuff Posted April 12, 2013 Report Posted April 12, 2013 Did you ohm your stator out? Sent from my HTC_Amaze_4G using Tapatalk 2 Quote
mccarthy_21 Posted April 12, 2013 Author Report Posted April 12, 2013 No i have not i am unsure of the specs Quote
Vicstuff Posted April 12, 2013 Report Posted April 12, 2013 There's a thread in the tech section that will tell you everything you did or didn't want to know about it Sent from my HTC_Amaze_4G using Tapatalk 2 Quote
Vicstuff Posted April 13, 2013 Report Posted April 13, 2013 its the next thread below this one but here ya go: Next, here are some electrical specifications for an '87 and up Banshee:Stator resistance:Ignition coil should be 13.7-20.5 Ohms (red to green wire)Pickup coil should be 94-140 Ohms (white/red to white/green wire)Lighting coil should be 0.26-0.38 Ohms (black to yellow wire)Coil resistance:Primary coil should be 0.28-0.38 OhmsSecondary coil should be 4,700-7,100 OhmsPickup coil gap: 0.015"-0.020"Spark plug: NGK BR8ESSpark plug gap: 0.7-0.8mm (0.028-0.032") Quote
thomas h. Posted April 13, 2013 Report Posted April 13, 2013 Replace spark plug caps with ngk rubber ones and cut coil wires alittle to get good connection. Quote
