03slowshee Posted March 19, 2013 Report Posted March 19, 2013 Doing the timing cover set at plus 4 degrees wondering what the pick up gap has to be set at. Any other advice wud be great Quote
wrreilly Posted March 21, 2013 Report Posted March 21, 2013 X2 or if you don't have feeler gauges, the thickness of a razor blade will do you just fine. Quote
trickedcarbine Posted March 21, 2013 Report Posted March 21, 2013 As tight as you can get it with out touching. Sometimes the nubs on the flywheel aren't totally the same so you have to file one down a touch to keep the gap the same over both points. Quote
