Which one are you talking about?  The straight-cuts or the lightened flywheel?
Lightened flywheel will let the engine rev up quicker, but also bog easier with a heavier rider.
The straight-cut gears will take the side-load off the crank caused by the stock helical-cut PTO gears.  They will also give you a couple more hp if you're chasing numbers.
-Jared
