2003bansheeman350 Posted October 19, 2003 Report Posted October 19, 2003 ok to tell you the truth im really not sure wats wrong with my quad? it all started when one of the paddles broke in my v force reeds. so i put in my boysen rad valve and... wel heres the problem im not sure if it ran with the boysen reeds in it :shock: so this is what i did so farr.. i checked float hight and set it at 21mm both carbs. the needle is seeting.... i checked jetting and cleaned the carbs good. i set the neele to the stock position after it being at one set richer than it and it seemed to run better but not even close to running normal. i was thinking it could be the intake boots that clamp to the cylender to hold the reeds in.. if anyone has the v force reeds than you kno that you have to cut some of the boot so it fits in rite, well maybe it messed up the flow ......... i dont know, could it? i put new plugs in it and checked almost all of the wires to see if they wer burnt..ect. i had a problem like a day ago before all this fuckin bull shit started with my tether kill switch, could a tether go bad and be a gay fuck and not run rite? the best way i can discribe the way it is running it like... it feels like it has a fouled plugs or cracked reeds. im positive im not runing to rich couse i leaned it out a little bit and it still ran like shit......................some one please help me :? Quote
Banchetta Posted October 20, 2003 Report Posted October 20, 2003 Disconnect the tors?? Equalizer tube in place between the carbs?? Slides in the right way?? Quote
2003bansheeman350 Posted October 20, 2003 Author Report Posted October 20, 2003 ok i figured it out (i think). im pretty sure it the coil. heres the reason why i think its the coil .........becouse the left cylender is blowing equal amount of smoke as the right exept the left is blowing cold smoke. so i took out the plug and it looks like it has never fired before, like it was brand new..... so the cylener is firing exept it's barely firing, i had my dad (lol) take the plug cap off while it was running.... it kept runnin a little worse than it already did, and then tried the right and it wouldnt run! what you guys think? Quote
Banchetta Posted October 20, 2003 Report Posted October 20, 2003 It means that one side isn't running properly, but doesn't mean its the spark.....Switch the spark plug wires and that'll tell you if its the coil. Quote
