Hello everyone, I just bought a banshee from a guy that didn't know much about it. All he said was that it is very fast. I took out the head to put a new gasket and I noticed that the pistons were 4 millimeters over the cylinders and the head was shaved 4 millimeters.  I have the pistons numbers which are D01J1  795M06400. I would like to know if this means that this engine is a 4 mil or what? The compression is around 150. If you guys can help me that would be great so I dont have to take the motor apart. Thanks. post-44542-0-16804100-1360134728.jpgpost-44542-0-67283200-1360134735.jpg
I´m no pro, but can that be a 7mill longrod? He is saying 4 mm over the cylinder!
If I can remember right the 4mill would be close to 1.7mm over the deck.
(not saying, just thinking)
If you read the piston, it means its a 795 series piston, which is made to go with a longrod crank(+5 mm, which is a 115mm rod), the wristpin is moved up to account for the longer rod, so port timing doesn't change. The 6400 stands for a 64mm bore. So in all likelihood, its a 350 cc motor, with a longrod crank. Unless the cylinders are ported and its a 4 mil. No way to tell without pulling a jug. Gl
