Well i've had my banshee for about 5 months but i've always had this problem where it doesn't start when its cold but i spray some starting fluid and it starts on the first kick and once it warms up i don't need to spray any starting fluid to start it back off when i turn it off  what do you think might be the problem?
i assume it is the low compression, 95 is low.
i took it to a local shop and they told me it was alright... what should the compression be at for a 392? but it runs really good when it starts that's why i don't think the compression is really the problem
so you have a 68mm bore? what BBK did you use? cub, vito, ect? and it should be over 120psi. really you would want it to be around 130-140psi.
yeah i have the athena 68mm big bore and i might have to check them again to see where i'm at right now
What other mods do you have? How are you doing the compression test?
well that's about it i have the stock pipes with some toomey silencers i'm not really sure about the size of the carbs but i'm sure they are not the stock ones
Does the choke work if not carb bowls are swapped ,zilla is rite compression is low might wanna get another test done and address the issue and watch who you have do the test not everyone does them correct
Um....what is your elevation? Are you using a quality compression tester and are you using it correctly? Sent from my Nexus 10 using Tapatalk HD
around 4400 ft to 5000 ft and i have used the matco tool compression tester and yes i think so
around 4700 ft and yes i did use a quality compression tester but thats when i barely rebuild it
Is there a small tube connectin the carbs in the middle? It's called a choke tube and that sounds like an issue I had. Wouldn't start unless I gave it just a little sniff of ether, then would run fine. It was all because of the choke tube. But that compression is a touch too low.
