cesar392tx
Everything posted by cesar392tx
  1. no the choke doesn't work and i will but today i took for a spin and change my main jets and the clutch gave up on me lol so i need to get a new clutch
  2. Hopefully that will fix the problem I'm thinking on getting new carbs soon anyways any recommendations?
  3. No I don't think it has it but I will put one tomorrow and its been a while science I did a compression test I will do one also tomorrow to see at what point it's at right now
  4. around 4700 ft and yes i did use a quality compression tester but thats when i barely rebuild it
  5. around 4400 ft to 5000 ft and i have used the matco tool compression tester and yes i think so
  6. well that's about it i have the stock pipes with some toomey silencers i'm not really sure about the size of the carbs but i'm sure they are not the stock ones
  7. yeah i have the athena 68mm big bore and i might have to check them again to see where i'm at right now
  8. i already cleaned them a couple of times but it didn't work
  9. i took it to a local shop and they told me it was alright... what should the compression be at for a 392? but it runs really good when it starts that's why i don't think the compression is really the problem
  10. i haven't checked my compression lately but it was at 95 on each cylinder. and what do you think on the jetting? the idle screws are set incorrectly? or the needle ?
  11. Well i've had my banshee for about 5 months but i've always had this problem where it doesn't start when its cold but i spray some starting fluid and it starts on the first kick and once it warms up i don't need to spray any starting fluid to start it back off when i turn it off what do you think might be the problem?
